Brief Description: Install prop, micro fill wheel pants
Installed the Sensenich ground adjustable prop, part number 2A2V5L56F, hub sn 28846, blade sn's 36927 and 36964. Set the initial blade angle using the maximum #5 pitch setting gauge for initial static runups. This should prevent full throttle overspeeds. Torqued to specs and checked tip tracking which was essentially zero difference.
Started filling seams in the wheel pants with "micro". I used 1 part polyester resin to 2 parts mico balloons to make a "paste" to fill the joints.
